alt/fan pulley -- which direction to turn to remove?
I'm having a heck of a time trying remove the nut that holds the pulley.
I want to make sure I am turning it the proper way.
If I set my ratchet to turn CCW (with 10mm TriSquare) and I try to turn the nut clockwise -- it doesn't move.
I tried to move it the other way around - but with less effort for fear of making it worse. no movement that way either.
Added a little WD40 to soak in, but no luck after sitting for a little bit.
Figured I'd ask before I do something wrong.
thx.
Mike
thx.
Mike
I'm not sure I understand tri square ???
Use the pulley holding tool. I usually turn the nut until the pulley holding tool rests against something.
Btw it's ccw. Lefty loosey.
What are you driving. ?
The 10mm tri-square (12 pt) is a male socket that fits exactly into the pulley.
Mike
