3.2 Stumble, no power after long idle (engine revs to 2k then falls to idle)
2nd Gear
New, irregular problem. On 4 occasions after my car idles for about 3+ minutes (e.g., at a long traffic light) it stumbles badly when I pull away. It will rev to 2000 RPM then fall back to idle. This process repeats (2k -> idle) until I hold the throttle down and I succeed in getting the engine above 3000 RPM. Then it drives perfectly again. It has only happened when the engine is warm, not necessarily hot (90oC).
This has happened 4 times in the past 300 miles and is very disconcerting when I start across an intersection.
The car is an '86 3.2 with 71k. I've replaced plugs, cap and rotor; checked for vacuum leaks; and adjusted valves. First thoughts are bad sensor (temp or speed) or corroded connector in the DME system (it's been a wet year in Washington).
Before digging it too far, I'm looking for suggestions from others who may have experience similar problems.
Thanks,
-John
Thanks,
-John
You may have water/moisture in the DME unit. Hopefully you don't have
a cab/Targa which would confirm this. Check/replace the DME relay
and check the fuel pressure. Also, make sure that the spark from the
coil wire jumps about 1". Bridge the temp sensor with a paper clip
to eliminate any possible connection problems with it, after the
engine is warm.
Good Luck
Loren
'88 3.2
engine is warm.
Good Luck
Loren
'88 3.2
