1976 911 S runs smooth 'till 2200rpm then a bit rough through 3200.....
and worsens as it warms up through 210 degrees. Timing? Fuel?
Year, make and model? ha
RL Technical Advisor
Hi:
Its hard to tell much from your very brief description but offhand, I'd say that its likely fuel related.
I would see where your CO is set at with a 4-gas ot 5-gas tester.
I'd also suggest that you make absolutely certain that the ignition system is in perfect shape.
