Possible ignition switch replacement?
Hoping someone out there can help with this. When the key is turned the car fires up fine, but when you let go of the key and it returns to its position, the car shuts off. It only stays running if you hold the key in ignition position and don't let it return to it's normal position.
Could it be that I just need to replace the ignition switch? Car is an '82 SC.
Thanks.
Thanks.
if you are looking for a replacement ignition switch here is a possible replacement for you.
https://www.carpartsdiscount.com/cat...ml?3593=267473
Please let me know if you have any questions or if i can be of any further assistance.
