HELP '85 Carrera Electric Window Switch?
I have a new switch for the passenger side power window but don't know what wire clips where? Anyone know where I can find a diagram?
Thanks!
1985 911 Carrera Cab
Thanks!
John Walker says,
"looking at the back of the switch, with the single terminal at the top, the red wire goes to the top and bottom right, the brown ground goes bottom left, and the two other wires from the motor go on the middle two. if the motor goes the wrong way, swap the middle ones. the right window won't work if the left window switch is bad, or wired wrong"
