Help: Non-working electric windows--78SC
Went for the monthly drive today and none of the switches for electric windows worked (two on driver's side and one on passenger's). Everything was fine last time I drove it. Fuse looked good. I even swapped in another one, but that didn't help. I didn't see any obvious problems with wiring around the fuse panel.
Any thoughts or hints for further diagnosis?
Thanks, Bill
Thanks, Bill
Swap one of the left switches with right side one. Be sure to make a wiring diagram so you'll know where the wires go when you replace it or put in a new switch. I don't think you have a wiring problem, but swapping switches will verify that fact. My right side switch has always "stuck" occasionally. If you have the switch out, spray it with electrical contact spray as it may need cleaning.
