2.4 911T-K CIS no start after warm.. starter doesn't engage -
Hello - may thanks in advance for helping me out -
2.4 911T-K CIS no start after warm.. starter doesn't engage - nothing no click nada -
Battery is strong- battery tender showing 100%
Ignition seems to be fine.. I can hear fuel pump engage..
The car wasn't that hot when I turned it off-
Any ideas are greatly appreciated-
Thanks again-
Thanks again-
Sounds pretty much like the starter has failed, or most likely the solenoid on the starter. Typically if you can get to the starter (under the car) you can attempt to "jump" the solenoid directly to the starter. This can help you determine if in fact the started / solenoid has failed. Replacing a starter on an early 911 is pretty easy. You ll need to get the car up on jacks to get to it of course. Replacement rebuilt starters are generally pretty inexpensive.
