911 Forum 1964-1989
87 coupe AC upgrade
Old 06-13-2015, 08:51 PM
  #31
PeterRM
PeterRM's Avatar
Originally Posted by wwest
Did you not read/follow the link..?
http://forums.pelicanparts.com/porsc...-c-system.html
Yes thanks, I did read it. That guy has removed the air duct to the rear blower fan to make room for the LHS electric fan.
I was hoping to mount the fans on top of the condenser (I have a whaletail) to maintain a reasonably stock appearance but that doesn't look possible at all.
I'll check the clearance on the RHS and see if I could run one larger, low profile fan only underneath.
Peter
Old 06-13-2015, 08:59 PM
  #32
PeterRM
PeterRM's Avatar
78-88 A/C upgrading... THE place to start.... Zims condenser/fan kit that mounts in the front of the left rear fender well, somewhat out of the radiant heat emanating from the HOT engine/exhaust and the even HOTTER catalyst
$500.00
http://www.allzim.com/store/cart.php..._detail&p=1240
Willard,
For my next car - assuming there is another GFC on its way and they become affordable again - I agree a Zim's kit and delete the original front condenser and hose setup all together would be the way to go.
Thanks for posting the Zim's link as I had not seen these before.
Peter
Old 06-14-2015, 01:57 PM
  #33
wwest
wwest's Avatar
Peter
'78 Targa, now history, had 2 spal pusher fans mounted under the whale tail. Fresno buyer happy with A/C performance.
WWESTED: The air duct was removed, and the blower modified, to increase airflow (~180 CFM) through the rear lid condenser. Long term plan is to use a 130dF thermostatic switch taped/insulated to the rear lid condenser inlet connections to power the blower and fans only as needed.
Old 06-14-2015, 02:02 PM
  #34
wwest
wwest's Avatar
Willard,
Peter
I'm not totally convinced that removing the rear lid condenser isn't a better idea, radiant heat from the engine/exhaust considered.
Old 06-19-2015, 01:00 AM
  #35
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Willard,
Would you put the temp sensor on the deck lid condenser inlet or outlet?
Thanks,
Dave
Old 06-19-2015, 12:23 PM
  #36
wwest
wwest's Avatar
Inlet seems more logical, widest temperature range/span.
Plus, placement wise, that's the logical equivalent of a trinary pressure switch.
Old 06-19-2015, 01:06 PM
  #37
Thanks, I just installed it on the compressor outlet, because it was easier to wire, and I think it should be the same as condenser inlet. I used connectors so I can change or eliminate easily.
Dave
Quick Reply: 87 coupe AC upgrade
