Considering a change out on my spark plugs and wires....
I believe each have about 50K miles. '88 Carrera.
Any issues with Bosch 7900 (ID'd as the OEM replacement) or the Fyrebraid wire set? Other recommendations?
I use the car for spirited driving and occasional mountain roads, but non-racing.
Do the wire sets come with the rubber protectors where the wires go over the fan shroud? Or the hard plastic wire separators?
I expect difficulty getting at cylinder 6 plug and getting the 4 thru 6 wires under the A/C compressor mount. Suggestions?
Remove the AC compressor as well as the blower tube on the left side to get better access. Not a difficult job with these removed. Use the Porsche spark plug tool as standard spark plug wrenches like to get stuck, especially in cylinder 6. If you don't have the Porsche tool, you can JB weld an extension to the spark plug socket so that it doesn't pop out and get left behind while you're trying to remove it!
As for which wires, I don't know. The OEM ones have removable/serviceable ends which people swear by, perhaps it's advisable to just get replacement wires and keep the stock ends? I'm not sure... When I did mine I just bought a new set of bright red magnacor wires. The lengths are good, they came with the plastic separators, but I do wish they were a more snug fit onto the plugs themselves. Overall I'm happy with them.
While you're doing this project, you might as well change out the distributor cap and rotor. Easy to do and inexpensive.
Tone, there is a spark plug that will make you pull, what is left of, your hair out. You have to use the wrench in the factory tool kit.
Only pull one wire at a time. ....ask Clive![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Replace the cap and rotor while you are in there.
I use the Bosch WR7DC in my '85. Never any problems. That may be the same as the Bosch 7900.
My wire set says Beru on it. It has been a while, but I expect I would have bought the Genuine Porsche ones, so I guess Beru is the OES on these. Plastic connectors included.
Spark plug wrench from the toolkit. Take your time.
I probably did this at the same time as a valve adjustment and took the opportunity to permanently remove the AC system, which made access a lot easier.
The Porsche wires are about twice as expensive as Beru OEM. I went with Beru OEM and the stock spark plugs. Used the tool kit spark plug remover and did not remove the compressor but did remove the stock air intake filter and outer cover. Made it much easier to reach, but not easy. Replaced the cap and rotor. Just keep your wires labeled. You should have a sticker on the body showing the spark plug location numbers to keep the wires straight. I've had zero training, but was able to swap the wires, plugs, cap, and rotors by going slowly. Good luck.
Former Vendor
I have the Beru's in stock CLICK HERE.
And Bosch 7900's and other's CLICK HERE.
Let me know if you have any questions.
-Jason
-Jason
