Hello everyone. Finally, spring feels like its right around the corner. Planning to put the axles back in and had a couple questions (out for clutch replacement & other misc items). I had a couple questions and wanted to see what you guys did in these situations. This is an 89 3.2.
1. See the pic below. Other than a good cleaning, does any put anything on the axle splines on reassembly?
2. I have read a number of people using locking washers along with the plates to fasten the inner CV to the trans flange. My car did not have the locking washers and those bolts were tough to get out (none were loose). I see the manual does not show the locking washer for this year. Was wondering what installation others had.
My 89 does not have the locking washers,just the double plates ... just make sure the holes where you thread the bolts are free of axle grease.
I use Qtips to clean the holes ... and put a small amount of grease on the splines.
It's a good practice to replace the allen bolts,i buy a box of 50 from a supplier like Fastenal and put new ones when I remove the axles for whatever reason !
Thanks Phil. I did read about the importance of having the cv end cap and flange very clean to increase clamping force. As you suggested, I will get in there with some Qtips so the bolts don't pick up and grease during reassembly. Also, I think I am going to go with the no washer approach too. I will make a habit of checking the torque on these every few months or so. Can't wait to get her back on the road.
