911 Forum 1964-1989
Headlight washers
Old 02-29-2004 | 02:01 PM
  #31
86NOH2O's Avatar
86NOH2O
Texaxgooner,
Where did you get the schematic print out? I could use it as well. Mine seems to be all in order now but still no go.
Also, what years are covered with this washer system diagram?
thanks,
Old 03-01-2004 | 12:48 PM
  #32
ron mcatee's Avatar
ron mcatee
I believe the nozzles are adjusted just like the ones for the wipers. there is a small moveable orifice that can be repositioned to divert flow where you want it. It may be stuck due to corrosion or caking of the fluids, but I got a straight pin and used it to reposition the orifice. Just stick the pin in the end and rotate to where you think the stream of fluid may go. Adjust from there if the stream is not where you want it.
Old 03-03-2004 | 02:40 PM
  #33
ron mcatee's Avatar
ron mcatee
I think the nozzles are adjustable like the ones for the windshield. I use a straight pin and insert it in the center of the small orifice. By moving the pin up or down and sideways, it should position the stream of fluid where you want it. It may take two people to do this so you can see exactly where the spray is hitting, since it is difficult to see exactly where it hits while you are in the car. My wife always helps me and we are done in a couple of minutes.
Old 05-25-2024 | 09:33 PM
  #34
StefanTerc's Avatar
StefanTerc
My pump was not working. Unistalled it, and when opened noticed that the gears where stucked. Easy to clean.
Old 05-27-2024 | 12:07 PM
  #35
theiceman's Avatar
theiceman
Team Owner
wow that could be a record.. 20 year old necro thread.
Quick Reply: Headlight washers
