911 Forum 1964-1989
Door Gasket Install Hints...
Old Mar 27, 2003 | 11:23 PM
GODZILLA's Avatar
GODZILLA
Post Door Gasket Install Hints...
...HellOOooo!...Just Purchased The Door gasket For My 1985 Carrera...(One Piece, Shaped To Door Opening)...Any Hints On Installation?...What Must I Remove, How Must I Remove Those "What's"...ALL Advice Will Be Appreciated...THANK YOU, In Advance!!!...AL... <img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" />
Old Mar 28, 2003 | 01:10 PM
ron mcatee's Avatar
ron mcatee
Post
Godzilla, It fits into the channel by pressing in on the rubber seal. The old one may have some weatherstripping cement holding it in, so if you tear the old one up getting it out, no sweat. Just clean the channel with Xylene or other chemical that breaks down the cement, but not the paint and make sure all of the old rubber is removed. When re-installing the new one, I always make sure it will fit, and then remove it and put a very thin bead of 3M weatherstrip cement on the back side and press in to the channel. This will keep the seal in place for a long time. LOL, should work ok.
Old Mar 31, 2003 | 07:21 PM
Bill W.'s Avatar
Bill W.
Post
I just did this on my '88 Cab. 3M has a solvent called oddly enough "General Purpose Adhesive Cleaner" P/N 051135-08984 made of Naphtha, Aliphatic, Xylene and Ethylbenzene. I used it on an old wash cloth and used a small PLASTIC putty knife to scrape the old rubber adhesive. Get the channel completely clean, then dry.
3M also has "Super Weatherstrip Adhesive" in both black and yellow (I used black). I think both products are sold at Autozone and Pep Boys.
Have fun,
Bill W.
