clutch pedal assembly removal
2nd Gear
I'm trying to remove the clutch pedal assembly from my 78 turbo. Can anyone advise how to access the two bolts holding the assembly to the fire wall. Thanks in advance.
I assume the 930 is similiar to the 911.
The following tech article should answer your question (they are studs for the brake master cylinder).
http://www.pelicanparts.com/techarti...al_cluster.htm
Bruce
Bruce
