911 Forum 1964-1989
Need Help on removing 3 spoke wheel
Old Aug 24, 2003 | 11:11 PM
Ocala 91's Avatar
Ocala 91
Default Need Help on removing 3 spoke wheel
I need to replace the turn-signal switch on my 1983sc. How do I remove the horn cover on my 3 spoke Factory wheel?
Old Aug 24, 2003 | 11:21 PM
Alan Herod's Avatar
Alan Herod
Lifetime Member
After you have disconnected the battery, grab it and pull it off slowly straight off, then disconnect the wire from the back of it.
Old Aug 25, 2003 | 02:25 AM
geo.aigel's Avatar
geo.aigel
Pull it evenly with a firm tug. I will complain with odd noises but should stay intact. If not, put a nice momo wheel in place. While you are at it, check your column bushing an replace with an insert if it has slop. $12 well spent.
George
Old Aug 25, 2003 | 02:45 AM
Stellpflug's Avatar
Stellpflug
Be gentle putting the cover back on after you are finished. I tried to snap mine back together, and two of the plastic fastners cracked. Luckily it was after I finished putting on my 930 wheel.
Chris
