Clutch Replacement
I was trained as a diesel mechanic in the Army, so I am a little bit mechanically inclined. I have only assisted on a clutch job for a Japanese car and it seemed pretty simple.
I did some research and found on the Pelican Parts forum a detailed plan to change the clutch.
I wanted to know if anybody had ventured into this land of clutch replacement and any tidbits.
Thanks,
Efrain I.
efraini@hotmail.com
Thanks for the pointer on the tranny. It'll come down.
The sears ATV jack is working great for getting the engine down, and around. It holds both the engine and transmission together (had to remove the rear muffler).
Since I don't have a lift... jackstands for the rear of the car, and removing the bumper gave me enough clearance to get the engine out from under the car.
If you follow the Pelican engine drop, things are very similar. You disconnect the transmission lever from under the car, not inside as they show (they discuss an older car)
Also, there is a "fork" that actuates the throw out bearing that has to be dissasembled before you can separate the engine from the transmission. For this you remove a dust cap, and screw in a 6mm bolt, that will allow you to pull the rod that the fork pivots on, and this will allow you to separate the engine from the trans.
Let me know if you have any other questions, I'll try and answer.
-Eric
(Last weekend I took things out, this weekend, I did a little cleaning, and next weekend I put everything back........ then autox)
I speak as the owner of an '82SC, and I note you're working on cars 8 years and 2 major reworkings newer, so maybe what I have to say is not relevant.
I have a list of "little things to do if the engine is out". Small things like a new crankcase breather hose, or new oil pressure warning lamp sender, new O-ring on the oil cooler thermostat. These are cheap parts, often impossible to get to with the engine in, that occasionally leak oil or may fail. I wonder if any owners of your model year have a similar list that they would share? Could save time & trouble later.
I don't have a list setup, but I know while the engine is out, I'm planning on doing some things... such as adjust valves, replace leaking main oil line, power steering pump cover gasket replacement,valve cover gasket replacement...maybe I'll setup a later on...
