A/C System Conversion/Upgrade
On my 3.2 conversion project I want to upgrade the stock A/C system to a more modern 964/993 one.
Does anyone have experience with that?
The ultimate goal is a more efficient system, and swap the dash/center console controls from this:
This could be a first. Lots of us just gave up and ripped it all out. I know I did. Heck, most of my heat is gone too. Next is taking out all the silly extra fresh air blower and box and going with two options: windows up, windows down. ....ok, I'm sorta kidding there.
$200 to convert to R-134a plus a few DIY mods and you can have an adequate system for your area. $300 if you throw in a new drier and a Red DOT trinary pressure senser/switch.
Your '88 already has the ability to provide additional engine cooling airflow if/when conditions warrant. HOT climate, consistently low roadspeed, engine RPM consistently to low to provide adequate engine cooling. That some ability can easily be modified for use as an auxillary method for additional , >2X (***), cooling of the rear lid condenser if/when conditions warrant.
Wire the binary switch section of the Red Dot to protect and control (limit the high side pressures to 325 PSI just as the EPA "requires"), and the third switch between ground and pin 10 of the cabin heater control module, in parallel with the engine oil temperature sensor.
If you haven't already tinted the windows then that would also help.
*** 3X with a simple DIY mod to the cabin heater blower.
http://forums.pelicanparts.com/porsc...r-upgrade.html
Very difficult to drop a 964/993 evap box in the front trunk.
The compressor is no better than the 10P15C: you'd need a different mount.
Quite a few have 'hacked' a 964/993 condenser unit in the LH front fender, but it is work.
By the time you custom bend aluminum or copper tubes for the runs you could have easily dropped in a set of barrier hoses.
If you are considering the 964/993 head unit.... hmmm, the stock center console thermostat and fan speed switch is more reliable compared to the later head unit. Then you will have to assemble some actuators for fresh air, mixed air, and recirc modes; not sure of the driver voltages you'd need.
But... if that is what floats your boat then go have some fun.
