exhaust smoke
8th Gear
exhaust smoke
I have not had my 1980 911sc out of the garage most of the winter. Shortly after I started it, I had enough blue gray smoke come from the exhaust to fog the whole naborhood. I shut the car off and let it set for awhile and again started it. Less smoke came out this time but still more than normal. I did a short look online and saw several posts from others stating similar situations with a long time between starts. They said run them for awhile on the highway and it usually stops. This I did and was satisfied that the smoke had subsided but at a stop light near home again a massive amount of smoke. As I excellerated from the light the smoke stop and did not reappear on the short drive home. Oil level was normal, millage 119k. Any ideas anyone?
They all do it. It was explained to me by a top P mech that the pressure from the piston squirters still bleed off pressured oil once you stop the engine. It pools on the back of the pistons. Over time it seeps past the rings. Sometimes the ring gaps are all facing down. Hundreds of threads on this. It's the puff.
Team Owner
Also he out accelerates all of us if we put him at the front he would be GONE !
