Smoke and Oil on startup
Yesterday, I started up my 73 2.4 for the first time in almost 2yrs. After the required prep it started up generating a humungous amount of smoke and blowing out the exhaust what looked to be a third of a quart of oil on the garage floor. I can remember it always had some smoke on start up particularly when it sat around a while but nothing like this. The engine has about 68K original miles. It ran strong but is this some fatal malaise or the standard reaction of a crotchety old engine ticked-off about sitting idle for so long? Thanks for your comments.
Team Owner
you actually had third of a quart of oil on the floor ? and it wasnt water vapour mixed with soot or anything like that ? and it came out the exhaust pipe ?
Sounds very bad if all that is true.
if oil is pouring out of the exhaist like that it is allmost impossible to believe it runs strong . You didnt over fill the oil by filling it up cold or anything did you ?
you are not a new owner so i would think you would know how to add and check oil.
I'm sure it wasn't water vapor. I had to get absorbent materials and work to get it up. It's hard to be precise on the amount of oil but it was significant. The car is in a large storage facility about 50' x 50' and fortunately there are only a few cars in it and no other people at the time but the smoke was enough to fill the entire area and cause us to leave until we could get enough ventilation to clear it. Scary
I haddah Google dat
After sitting, it's normal to have a lot more smoke than usual at startup. If you have a huge oil leak(s) then you'll have to clean the motor so that you can find fresh oil and fix the leaks.
