Horrible noise 993 help!
Ok so this is definitely just a fair weather weekend carver. I drove it two weeks ago and it's been in the heated garage on the battery tender since. Went to start it today and there is this horrible ticking noise. I was thinking either a lifter failed or an exhaust leak. I have the fabspeed supercup exhaust. Here's a video of the noise.
I think you might have a bad or lazy lifter, but +1 on getting advice on the 993 forum.
https://rennlist.com/forums/993-foru...air-101-a.html
Yeah, there's a few things going on there. First, the exhaust is pounding away, but there is a slower frequency tap-tap-tap. Hard to tell exactly how loud it is. The OP should use a mechanic's stethescope or long metal rod pressed to the ear to isolate which cylinder it might be, and whether it's intake or exhaust.
PATIENT: "Doctor, my neck makes a funny sound when I move it like this..."
DOCTOR: "Then don't move it like that"
Seriously, given the $15K+ cost of a 3.6L motor rebuild, I'd consider taking the car to you local Porsche Specialist.
Hopefully, its just a bad exhaust gasket, or a loose mount, or exhaust baffle... but if there is an engine problem, fixing it now will be a lot cheaper than cratering the motor.
Hey thanks for all the reply. I'll post this in the 993 forum as well. Yah there is a higher pitch tapping noise associated with it. I'll have to try out the stethoscope. Using full synthetic and the car ran flawlessly last time I drove it. The nearest porsche specialist is in Boise but I have a flatbed trailer and a truck so I'll take it up. What is the name of your son on his mission? My pops is the stake mission coordinator lol!
