central door lock problem
Hi, I have an 87' 911. Today, the passenger lock only unlocks when I hit the central locking button or I hit the remote to open or I lock the car when turning the key in the door handle. I can't get it to lock. Any answers to this problem and how easy a fix is this? Thanks . Chuck
Hi. That happened to me too. It was simply the linkage had come apart behind the door panel. I took the panel off and cleaned everything up, replaced the nylon connectors (low cost), and everything has worked fine since then.
Hope that helps.
Hope that helps.
