72 911 calipers
02-15-2014, 11:52 PM
72 911 calipers
Are the 1972 911 S caliper aluminum from the factory?
02-16-2014, 12:29 AM
Maybe I should ask it this way, what is the difference between S brakes and say T. I believe the 2.4 E also came with " S brakes"
02-16-2014, 07:46 AM
AddictRennlist Member
Quote:
Originally Posted by
Baxter2012
'72 S front are aluminum, 1 piece S on 282x20mm vented rotors on 3.5" struts, rear are iron, 2 piece(w/ spacer) M on 290x20mm vented rotors
E did not come standard w/ the front S calipers. Both T and E came std w/ iron M calipers and 3" struts on the same rotors
02-16-2014, 08:39 AM
Baxter, I have a spare set of the light alloy front S calipers available. If you are in need send me a PM.
Marty
