Can I order a Porsche with optional Day Time Running lights like the manual saids?
Here is the situation, my manual for my Porsche said that I can disable the Daytime running lights as long as its not mandatory in my country.
I live in the USA and daytime running lights are not mandatory so therefore I should be able to turn them off however the options does not exist on my Caymen Porsche.
Could the Porsche factory in Germany incorrectly be labeling the USA as a mandatory Daytime running light country even thought they are simple allowed but not mandatory?
Has anyone ever figured out how to turn them off or why the option is not showing up like the manual said they should ?
The reason I ask is because I am ordering a new 911 Porsche(991 model) from the factory and I want to make sure I have the ability to turn off the Day Time running lights .
For reference, here is a copy and paste of the manual:
The "Daytime Run. Lights" setting can only be changed when the vehicle is stationary or moving at walking speed.
The function is only available in countries where daytime running lights are not mandatory.
Press the button.
Press the button or touch the tab of the same name in the header.
Select "Individual memory"
> "Light".
Select "Daytime Run. Lights" to activate ( ) or deactivate ( ) the function.
Press the button.
> "Light".
Hi JD:
On this Forum (911's up to 89') our cars come with driver/manual controlled DRL's.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I have never looked in to deactivating this feature on my 991. I would try the 991 Forum after doing a "search" first.
As it sounds like you are on your way to becoming a Porschephile, you should join Rennlist.
