1979 SC w/3.6 or 3.3T? (964)
So I recently picked up a 1979 SC, car is stripped with cage, 55k miles. I'm looking to make it a weekend warrior, neighbor annoyer, seldom track toy.
I have been pondering 3.2 swap but then I stumbled upon a 3.6NA engine and a 3.3 turbo engine. Am I crazy to slap the 3.3T engine into the car?
I'm looking for opinions honest, brutal and etc don't be shy.
No the budget is not unlimited.
No. But in 2014 I'd do the 3.6L every day of the week, and twice on Sunday. Go drive a 930, and it will become plainly obvious. Only slightly gets better when mated to a 915 5-speed box.
Biggest consideration is what you think either of these jobs is going really end up costing you by the time it's reliably and competently done.
(Did too many of these conversions in the '80s and '90s, doubt any of the turbo guys were ultimately happy until you started wholly modifying the turbo engine.)
Redridge the car will be for DE/Weekends/Daily use. I'm not setting it up for class racing but I want to set it up so it's the most fun I can have in my personal use. learning to drive a 70's car with 90's power I don't see a problem since I have been lucky enough to have driven anything from early Ferraris to current day "exotics."
Ken I do like the 3.6 NA simply because it's NA and with EFI conversion I think it could come close to 300 rwhp. The 3.3 would also become EFI with modern day turbo so the 80's lag would not be present. Biggest thing is will the extra few grand for the 3.3 conversion be worth it over the 3.6NA.
At the end of the day the car will be completely stripped with some lexan pieces so I see it at around 2000lbs.
Ps. I am a turbo addict
You have the choice between a somewhat plug and play reliable hydraulic lifter 3.6 or a 3.3 tappet valve hand grenade ... i'm very pleased with the 95 3.6 i installed in my 2650 lb 89 !
Cheers
Phil
Cheers
Phil
Sounds like 3.6 it is
I'm not sure I'd call a well set up 3.3 turbo in a 2000 lb car a dog. I had a well done 930 and car was a rocket. The 3.6 will be much more reliable and durable. The induction systems on all these motors limits the response to some extent. Enjoy sounds like a fun project. I just picked up a 79 wide body SC with a carbed 3.3 NA motor, should be fun. I'll report back once I have driven it.
Phil
Phil
Phil
Phil
So did I.
But really, it depends on what you want from the car.
You can go crazy on the turbo path and end up with something that's like riding a jet fighter with no wings. This might be exactly what you're looking for. There's no substitute for the thrill of pure acceleration. And it's safe to say that the sound and the smell of shredding tires will be very effective at annoying the neighbors.
The 3.6 is less extreme and more precise. It's also much more cost-effective than a turbo addiction. My car will not snap anyone's neck back, but I've had a couple of passengers lose their lunch -- it's pretty quick around a track. There are a bunch of different reasons for why my particular car works -- the linear power delivery of a 3.6 is one of them.
But if the thing you want is to have your passenger scream when the boost kicks in, then definitely go with the boost.
Mine scream in the corners.
![](https://thumbsnap.com/sc/Z7hunlfg.gif)
