A/C delete
I am taking the a/c out of my 83. It was added (not stock) and didn't blow air that was even a bit cold. Plus it's a cabriolet so who needs a/c, especially is San Diego
I assume the line going from the driver's side of the condenser goes to the compressor, right? Any suggestions on getting it out?
You will also find many little brackets holding the hoses to the tub, all held on with sheet metal screws. I tried putting the screws back to fill in the holes, then realized I didn't want them vibrating out when I'm on the track, so I removed them all and filled the holes with quick setting JB Weld. Some people use silicone adhesive,
My suggestion on getting it out is to do it ASAP...
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
