Can this be fixed? Odometer repair.
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Hi everyone.
I am in the process of replacing the plastic gear (20X30 teeth) which became jello due to age etc.(as is well known in older 911's; speedo works mileage doesn't turn over). Mine is a 1982 911SC bought last month (I knew when I bought it and planned on doing this repair). I need some advise from the more knowledgeable and experienced gang here. You see, when I opened it up and after I managed to remove the tumbler unit found a single white piece of plastic (shown in pic-1) fall on the table. I managed to find where it broke off as shown in pic-2. I just gently located it adjacent to where it would have been (pic 2) to take picture. Does this mean I am screwed and cannot put my unit back together without this plastic piece in the right position? Can I glue this back, and is it even possible? I feel like all my work now may be for naught if I cannot put back the speedometer together because of this broken piece. Any and all help is much appreciated.
KK
KK
Skunk Whisperer
Your pic links no worky but herehttp://www.pelicanparts.com/techarti...ter_Repair.htm is a link to a book I use for 911 repair. The link is for the odometer repair. Hope it helps. GL
Charles, thanks. It appears it is not easy to post pics in this forum based on my search. I am almost there in putting the new gear and be done with; but want to make sure this broken piece will not affect function, (to me it doesn't seem to) but wanted to confirm so I don't have to pull my speedo again from the car after everything is said and done. Unfortunately I am having trouble showing the pics.
My previous post boils down to, does this small piece that came off will screw up the function of the speedo, even though I don't see how? I played with the reset button to see if this has any impact when I took the picture, but didn't see any.
Thanks in advance..and I hope the pictures show up this time.
Skunk Whisperer
Don't remember that piece but it has been a long time since I have seen the inside of an 911OD. That looks to be a upper(trip) tumbler clip/retainer. I have had good results using a micro torch to re-weld plastic together but with a part that small you will need rock solid hands, as well as a few sacrificial shavings from a non-critical area of the OD that has the same plastic. Epoxies might work but you will need to test the effectiveness of the bond. Hopefully someone with more knowledge will chime in. GL.
