1977 911S with mods. Is it reasonable?
A friend of a friend in the East Coast wants to sell me this. I know nothing about mods, except that I know I want an inexpensive car to have fun on the track that doesn't break me. Asking price is $11.5k. Is this reasonable? I have never seen the car and thinking about buying it sight unseen. Also, I am in CA -- what is the smog requirement for this car if any? What does it tak to pass a smog test if needed?
Thanks for any help you can give me.
These are older photos new one would show European headlights H4
the usual mod pop off valve
pressure fed chain tensioner
2.7l cis engine with 3.0l intake manifold S cam rebuild 5000 miles ago
heat works( as you know )
breakerless ignition 16x7 and 16x8 fuchs wheels with extra set of fuchs 16x8 and 16x9 if wanted
original leather seats included
extra front cross drilled rotors
suspension rebuilt less than 1000 miles bilstein as seen in pictures
turbo valve cover with heat shields
turbo tie rod and adjustable f and r sway bar
poly urethane engine and transmission mounts
Hargett shifter
alpine stereo with amps
shock tower brace (Renn Line)
free flow intake with K&N filter
magna core ignition wire
back dated exhaust (loud)
roll bar bolted in
sc flare on 1977 body
fiberglass hood
fiberglass ducktail and rear engine cover
fiberglass yellow bird bumpers by MA Shaw
street lega track car
in car camera if wanted
remember that you are in California this cart has no emission equipments
Hargett shifter
roll bar bolted in
fiberglass hood
Jump on it quick....very quick.
May want to question the condition of the head studs on the 2.7 and research what smog equipment is missing. Guessing you will need to replace the exhaust too. Still a screaming deal.
RL Technical Advisor
Looks like a neat car!!
'77 CA cars must pass inspection & testing. Those cars had thermal reactors & air pumps so if that's missing, you'll not pass smog until everything is in place.
+1 I'm on the East Coast. I would fly in buy that car and drive it home. Live in SC too so no smog to worry about. Pass on his info to those interested if you decide to pass. Good Luck!
Seems like a great deal. Neat looking car.
