Carrera rear brake cooling?
Anybody have any ideas on how to rig up some kind of rear brake cooling system on a 1984 Carrera? I'm in the process of installing a ducted system for the front, and I want to cool the rears as well.
Skunk Whisperer
Without cutting metal or running long ducts, this looks to be simple but you realy have to be a very, very late braker to worry about rear brake temps. Now, how effective it would be depends on intake placement and body height/air flow. Pelican has a few write-ups on it. Simple search will get you more info than you need. GL
![](http://forums.pelicanparts.com/uploads17/IMG_17621275723040.jpg)
The calipers are good; I just redid the piston seals and I tested them before reinstalling. Maybe I need a new p/v. Is there anyway to test it?
Have someone watch (or shoot some video) while you do heavy-to-threshold braking in a safe place -- check to see which wheels lock up first. If it's the rears, you might have an issue.
I'd suggest that if you had too much rearward bias, you'd know it already.
(I have an adjustable rear bias and tend to set mine right at the limit, i.e. VERY strong rearward bias. I have yet to note that I may need rear cooling despite the fact that I wear rear pads out at almost the same rate as I wear the fronts)
so if I stomp on my brakes and rears lock up, there is an issue with that rear caliper(s) that locked up? Should the fronts lock up before the rears? Im new to this non ABS stuff. TIA
Yes, but don't stomp. All four will lock up. Go from medium-hard pressure to full pressure.
But KaiB is probably right. Especially in track driving, you'd have some serious issues if your bias was too far off. But it's a pretty easy thing to eliminate by testing.
And it could be that there was brake fluid present when the calipers got repainted.
Dont want to hi-jack the thread but what are the things to do to eliminate rears locking up?
I was bedding in my brake pads and the rears were locking up (while stomping the brakes)... I take it this is normal? The ground had dew on it...
When was the last time you flushed or bled them?
