1986 911 brake Indicator problem
The dash indicator light cluster for the emergency brake, brake function and pad wear does not light up at all. It seems pretty difficult to access from behind the dash. Any experiences with this and how to address it. I checked a couple of my manuals and couldn't find anything. I thought it might be a fuse but none are listed for these functions. Thanks.
If the clock proves to be difficult to remove, then reach in from the trunk and push it out a bit. It can then be pulled from the interior.
For re-install, spray a little glass cleaner on the rubber gasket to ease installation.
