911sc runs bad, professional help wanted!
Hi,
I'm working om a 911SC from 1983. The car runs bad when cold small backfiring, runs to lean?
- I checked the vacuum
- set the valves
- Idle set at 900 RPM
- checked the timing with a timing light.
- Timing is good at idle bud doesn't enhance enough in higher RPM
- checked the vacuum by sucking on it. Doing that the rotor enhances. So its good?
- CO is at 2,5% any lower it runs bad
- spark plugs are new
- cap and rotor are new
- frequency valve is working
Replaced the O2 sensor tried to read it whith a dwell meter but no result!
What might be the problem with the dwell?? Or whats wrong??
Thnx in advance
- set the valves
Thnx in advance
http://www.pelicanparts.com/911/tech..._Bosch_CIS.htm
There is a book by James Weber called Bosch Continuous Injection Systems that is very good but it appears to be out of print. See if you can find it as it's invaluable working on CIS fuel injection.
https://rennlist.com/forums/911-foru...-solution.html
Good luck! CIS is great when it's all working properly but can be a real PITA otherwise...
Hi all,
Thanks for the many replies!
To Shannon123: I allready but new gas in.
To Steve Weiner-rennsport system: I'll check my pressures next week and let you know. O, and waht's WUR?
To troYn: Thanks for the testing procedure, I'll use that
To Peter Zimmerman: I checked and adjusted the CO allready. The car has cathalytic converter.
Hi all,
Ok, I don't have the right pressure tester. I'm going to buy P378 according to the Porsche manual. Its the same as vw1318:
http://www.mytoolstore.com/toolaid/diagn02.html
Or does anyone have better suggestions?
roadster49 (04-24-2020)
Measuring CO% AFTER the cat tells you nothing. To set CO on a USA '83 SC:
1. Open the test port at the front of the cat
2. Disconnect the OXS wire in the engine compartment
3. Hook up & zero tester
4. Start engine and bring up to temp until the front oil cooler is hot to the touch; idle speed = 900 rpm
5. Check CO - use test port and be sure that the hose on machine cannot suck in outside air (hose should fit snug at test port and machine)
6. Spec = 0.4 - 0.8%
7. Adjust as necessary - always turn the wrench toward rich (clockwise) before moving toward lean. Never leave the wrench in the adjustment hole, or lean against the airbox, while checking/adjusting.
Connect the OXS wire, close the test port, and go for a drive. Now, if you don't have a good running car, you can begin to diagnose the problem.
Hi Again,
The tester is on factory backorder until the end of August. Your
costs including shipping would be $200.75 USD via US Postal Service or
$241.25 USD via UPS
So, thats no sollution from mytoolstore.com....
Is there any other way to test the WUR?
I also replaced the O2 sensor and tried to read it with a dwell meter, no results at the testport. Anyone any experience with this?
$241.25 USD via UPS
