Alternator /cooling fan separation
I am in the middle of an alternator replacement. Any advice to separating the old alternator from the fan? I do not have access to a press so thats out. I really don't want to bash the crap out of it
Help!
Rod,
Help!
Rod,
this comes up pretty regularly . After the woodruf key is out I think the consensus is to work your way around tapping it at the back with a hammer and a block of wood till it starts to work off the shaft .. you could heat it up a little with a heat gun too , that may help.. Oh and when you get it off , there is a guy on pelican who cant remember if there are any washers or spacers bakc there on a Carrera so let him know
I used a punch and small hammer. I gently tapped the alternator threaded studs. I working in a star pattern across the alternator to avoid having the alternator get wedged into the housing.
Every few threads, I would try to pull the alternator out of the housing.
Glad it worked out Radcap. Here's a good write-up as well:
911 Alternator & Voltage Reg Removal & Replacement
Let us know how it goes when put back together.
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
"Here's a good write-up as well:
911 Alternator & Voltage Reg Removal & Replacement"
Actually not! The second paragraph of "11" results in damage to the alternator
AND is noted as such in the writeup.
11.)You will now note the "other" three, 8mm head nuts ( that you couldn’t get to earlier when removing the air-duct). These 3 hold the alternator to the cast fan housing . Remove these 3 nuts, noting their location [ that is, whether or not they were included in holding the air-duct funnel. I used this approach: the nut that straddled the regulator centerline DID NOT hold the air-duct funnel. Every "other" nut ( in a staggered, 120 degree pattern) also DID NOT hold the duct. The remaining three DID hold the air duct.
Alternator will likely be "frozen" to the housing. With caution, use a hardwood ( or such) to tap on the 6 bolts to get it out. I even used heat from a hair drier to "expand" the housing, which helped. Patience ! Go in a circular pattern. I used a metal hammer, which worked, but I "flattened" the end of the bolts slightly causing grief when re-installing the nuts.Don’t do this !
The proper procedure is to use a block of wood, e.g. 2X4 or 2X6, and tap
the fan housing on the wood with the alternator facing down. The assembly
is rotated as it's tapped on the wood. The alternator will easily 'fall' from
the housing with a few taps.
+1 on patience. I re-install the nuts to protect the threads. Use baby-taps. Persistent, light tapping. That fan shroud is un-Godly expensive, and as rare as unicorn farts.
"I re-install the nuts to protect the threads. Use baby-taps. Persistent, light tapping."
Never a good idea to hammer on ANY Porsche engine parts especially when
a better method exists. Only gas station so-called mechanics (basically
butchers) use hammers on Porsche engines.
Bottom line: Use wise discretion when following explicit engine repair instructions
from postings on the internet!
