ALL 83' SC OWNERS
ALL 83' SC OWNERS
What the hell?? For everyone thinking of changing oil and cleaning sump plate screen, don't bother...there isn't one. Found out to my chagrin the 930.16 engine, 64D3_ _ _ _ or so and up didn't have one. What I hear is it was the happy preparation for the carrera 3.2 case. (One less gasket!!) so later production's 86'd it........Guess my beloved 83 cab has a mongrel engine of sorts.....Now to find a safe jack position??? any ideas?? sean
If he has the single drain plug, it would require a completely new case-a pretty BIG deal.
Use the motor, or you need to go side to side. Or, a lift!
[QUOTE=Ed Hughes;10251138]If he has the single drain plug, it would require a completely new case-a pretty BIG deal.
He said he had a 'sump plate' so I thought he was missing the screen only, if he has the later casing what's the issue?
Peter, (or anyone) hello: Question, how does this affect oil changes? without the 2/3 quarts coming out of the sump on drainage and 10 or so from the pan, whats the best way to get all of it out? drain, re-load, heat-up and then drain again?? Kind of strange they would modify case right in the middle of production.. thanks
