Brake pedal not returning?
I have been looking at a 1980 911 SC for potential purchase. Nice car, good condition. The owner tells me the brake pedal will not return. I haven't seen it in person yet but was wondering from you experienced lot, what is the worst case scenario for a non returning brake pedal?
Thanks!
Thanks!
Has the owner had the issue diagnosed? Could also be a pedal bushing problem, but it's unusual enough that you should cover yourself by getting a price reduction for the car if you pursue its purchase. Don't forget to read my Pre-Purchase Tutorial at the top of this (911) forum.
Thanks Guy's. Pete, I can almost recite it from memory. If the spring is no longer available, I would imagine you're looking at an entire cluster replacement? I assume there are kits for that?
I've seen calipers in such bad condition that they were at fault, making it "seem like" the pedal was not returning. Ask the seller when the brake hoses were replaced, the required time is 10 years or 100K miles, and if the calipers have been rebuilt/resealed.
