Most reliable 911 model
I am new to the forum and contemplating buying a Porsche 911. I was seriously considering an 83 911 Cabriolet with 36K miles but now am not sure. Having read the horror stories about the "bullet proof" motors breaking head studs I may reconsider and look at another vintage. I did some searches but can't seem to find a definitive thread on the subject. Any input would be great.
Team Owner
wow that is a HUGE question .. But I can tell you you wont go far wrong with a PPI'ed SC or Carrera.
My SC has had zero issues in 8 years other than the self induced stuff and Carreras are pretty much the same.
It might be argued that the Carrera is even more reliable as it does not have CIS , but my CIS has been flawless and the Carrera has some issues with relays, sensors and the like which is to ne expected with a more advanced car.
Sure head studs can break and it does happen, but i would not say it is common at all.
I think you would be fine with a well Sorted SC or Carrera undestanding that there will be issues from time to time ( thats why we are here ). Which one you choose depends on personal preference and budget.
As you do your research I am sure you will discover the folowing thigs to watch out for.
SC :
1. Backfiring through intake, hot and cold starts, and smooth running ( CIS issues)
2. Broken head studs
Carrera:
1. High oil usage and smoke on decel ( worn valve guides )
I would take any of the ebove cars over any modern car with potential IMS issues, D-chunk , porous casings or coolant pipe issues any day.
SC :
Carrera:
Dan, the head stud issue usually comes from cars that have been driven infrequently, and when driven not brought up to normal operating temp. Short drives and stored...the engine 'sweats' and not hot enough to burn off moisture and a stud can carrode/break after years of use.
I have a very high mile SC that has all its original studs, lots of them survive just fine.
Do a PPI and have them do a leak down and head stud check.
a car with low miles is always no-no to me, not due to odo. fraud or anything, but in general machines don't like sitting unused for long periods of time...a SC with 150,000k miles thats in good shape means its been maintained for 30 years not sitting around for 30 years
Team Owner
With all due respect i dont know if i agree with the above two statements. What we can as fact say is that some head studs break , To say they are on low millage cars, and that it is on cars that dont come up to temp i would say as an extention. Also to state low milage cars will have more issues because they dont like to sit ? ... dont know.
I am not saying these statements are not true . I am saying they are not reported fact.
( You have to keep in mind I am an engineer who works in the medical field ) .. and when when you are reporting issues you have to seperate what is reported and just report that along with the facts in front of you , the root cause comes from further investigation.
Again I am not saying the statements arent true .. just that i have not seen concrete evidence to support this, that shows cars with broken studs broken down by miles on the car. I have heard of some older cars with broken studs too.
Studs with moisture ? not so sure .. put your hand on a cylidner after its been running for oh say 10 seconds recently ? I would agree with this comment for exhaust though . it is a fact exhaust produces moisture and you better get that hot .. dont think that is tooo much of an issue on a 911 as oppose to the 12ft exhuast on my A6 tho ..
anyway not dissing anyone .. just providing some perspective.
As far as cars that arent driven dont like to sit ? .. i dounno .. i think id take a Carrera that they found and forgot to sell...
I do agree however that some parts need to be repalced and maintained because of time rather than miles ( UV damage etc ) .. and if this has not been done you will likely have to do some of these .. but all things being equal and those things were maintained .. just not a lot of hours on the engine or gearbox i think i would take it.
just my 2c CAD
just my 2c CAD
Yeah I've heard that rumor about the headstuds before, my comment is not specifically related to that, its my general feeling towards all cars... hell any motor, a car that runs 150k and runs great, and has lots of main receipts is more appealing to me than the dude that drove the car 1k a year, theres bound to be a lot of older parts in there that will be more prone to fatigue failure simply due to age. Just because a car sits doesn't mean that parts weren't subjected to stress and moisture (unless stored the really really proper way)
I have no comment on whether or not the head studs issue is true
For 11 years I've been running an '87 Carrera to red-line and back. The only engine maintenance my car has received is from the items I wanted to change (spark plugs, cables, etc.). It's been 11 years of virtual maintenance-free driving. Now I'm running the car at the track (maybe 40 days so far). It seems odd but I'd swear the harder I run the car, the more it asks for the same. It wants to run. I suspect the SC & Carrera would be a wonderful entry car with a supporting PPI. Enjoy your car search & drive plenty of cars to find the one that feels right for you. Any work you perform on it will be a labor of love.
Dan and Ice....I have limited experience with the SC but both of the Indy shop guys I use (Jackson, Stuttgart SW) told me the same in their experience with the head stud deal. They've seen more breakage issues on low mileage cars especially if from cold/wet country.
A bit of info for you regarding 911 head studs. This writing is done from personal experience:
Cylinder Head Studs
1977. Porsche was well aware of the problems associated with the 2.7 liter engine with its pulled cylinder head retaining studs following a repair that required cylinder head removal; sometimes the studs would pull without apparent reason. Porsche knew about thermal expansion, and had used, since the early ‘70s, in racing engines, a cylinder head stud made from an alloy called dilavar, while all street engines were assembled with steel head studs.
Dilavar studs, first used in 930 Turbo Carrera engines, were found to have roughly the same thermal expansion properties as both aluminum and magnesium, which, in theory, would greatly reduce head stud stress at higher engine temperatures. It’s been written that steel studs, on the other hand, have an expansion rate roughly half that of the aluminum cylinders and cylinder heads that they hold together, which put extreme loads on the crankcase and the studs themselves. Dilavar studs, a non-magnetic steel alloy, found their way into 911S production part way into the ’77 year, but the studs were only used in the bottom twelve, exhaust side, positions (each 911 engine uses 24 studs, 4 per cylinder head). A thoroughly tested no-brainer, or an experiment, I don’t think that anyone knows the answer to that except for a select few people at Porsche. The first dilavar studs were a shiny, brushed finish, similar to many modern kitchen cabinet and drawer pulls, with a color closer to silver than to light gold. Their purpose was to stabilize cylinder head torque through the temperature range that the typical 911 engine ran at. I’m sure that the factory hoped that Dilavar studs would also be the cure for pulled head studs in magnesium engine cases. Because the thermal expansion rate between early steel studs, and the alloys that they secured, were quite different, the change was made.
1980. The first improvement to dilavar studs was made for 1980 SCs, which proved that Porsche was committed to their use. The stud changed in appearance, to an almost jewelry gold finish. For this design change to happen so early into the use of dilavar, Porsche must have seen, and not liked, corrosive activity on the first generation stud. Factory literature states that Porsche’s original philosophy of using twelve upper studs made of conventional steel, and twelve lower studs made of Dilavar remained consistent beyond the 1980 models. At some point Dilavar studs were again changed, and the newer version was coated with a gloss-black paint-like substance obviously designed to withstand corrosion. This change was thought to have been made during 1981 production, or at the outset of the 1982 build run.
OK, you’ve read the first part of this chapter and are probably wondering why. Well, if you own a ’78-81 SC (or a '77 911S) the subject matter above could easily make you about $3K poorer. Head studs break. Some more often than others, but mostly the problem occurs with the uncoated, early studs, followed by the second generation, also uncoated, studs. The studs break about two inches from the end where the head nut screws on; they are obviously susceptible to corrosion at that point. A fastener such as a stud, or bolt, is under constant stress, from the time that it is tightened until the time that it’s loosened. The act of applying torque to a fastener is the actual stretching of, in this case, the stud. Enter corrosion, which attacks where it can, and begins to eat away at the metal. Remember, dilavar is a steel alloy, it is not immune to corrosion, actually far from it. At some point in its life, a corroded head stud will snap at its weakest point, and will no longer provide the fastened strength that a cylinder head requires at each of four corners.
Head studs break on low mileage cars; perhaps more often than on high mileage cars. “How can that be?” one might ask. No one knows the answer, but I know it to be true. I also know that it doesn’t happen to all cars, maybe even less than ten percent of each involved year. My shop replaced head studs on far more cars with less than 50K miles on the odometer, than with more than 100K miles. It can create a bit of a conundrum, the cars that can be considered garage queens, and are obviously the most desirable to find and buy, are the ones that have this potentially expensive time bomb lurking in the engine bay.
FAQs:
“How does one know when a head stud is broken?” All 911s built between 1978 and 1989 have the same maintenance requirement for what is normally referred to as a major service – typically required at about 15,000 miles. That service consists of a valve adjustment, oil and filter change, engine tune up and other items. In order to perform a valve adjustment, the valve covers, aka rocker covers or rocker arm covers, must be removed. There are four covers per engine, and are usually referred to as intake (upper) covers and exhaust (lower) covers. During removal of the lower covers I have been hit on the foot by a two inch long piece of a head stud, with the cylinder head retaining nut still on it. Sometimes the broken piece will fall out; sometimes it will hide in a recess in the camshaft housing casting. A normal major service inspection should include, especially on high-risk cars, a visual to verify that all of the studs/nuts are intact.
“What is the immediate symptom?” Usually there is no symptom, especially on conservatively used, commuter or weekend cars. I’m aware of cars that have been driven thousands of miles after a broken head stud was diagnosed, with no negative result.
“When does stud replacement become something more expensive?” If one or more broken studs are discovered during a major service and the needed repair is ignored, at some point a corner of a cylinder head, usually the corner with the broken stud, will work loose enough to leak combustion (the gases that are supposed to leave the combustion chamber via the exhaust valve). From the very moment exhaust gases begin to leak out between the cylinder and cylinder head the process of erosion begins. Eventually a cylinder, possibly even a cylinder head, will be damaged beyond repair.
“Is there a symptom when it’s almost too late to do the basic stud replacement without extra cost?” Yes, the driver will hear a distinct and rapid “pop, pop, pop…” during acceleration; louder with a cold engine than a warm engine.
“Is there any way to ascertain the presence of a broken stud without hearing the popping noise, or removing the valve covers?” With the car raised up enough to see the bottom of the engine, a flashlight examination can be done of the areas where the cylinders and cylinder heads join. Those areas should be dry and clean. If there is a black, crusty layer that appears to be burned oil, there is a chance that the engine has one or more broken head studs where the buildup is the heaviest. However, a broken head stud is not always responsible for this condition, sometimes it is from a tiny imperfection in a machined surface, and no immediate repair is required.
“If my engine has broken studs can the job be done so the repaired engine is a long-life unit?” Going by everything that is known today, the current generation of cylinder head studs, developed for the 993, should be trouble free for at least the service life of the engine that they’re in.
“If my engine was originally fitted with steel upper studs, and Dilavar lower studs, should all 24 studs be updated to Dilavar?” Porsche must have done temperature analysis regarding the required expansion of the upper and lower studs, but I’ve not seen a technical bulletin advising the correct way to handle this. My shop found evidence of corrosion on original, steel upper studs, so our policy was to install 24 new Dilavar studs on engines with corrosion. We also re-used steel upper studs when they were in fine condition. Follow up inspections showed no adverse results regarding those repairs.
“Are the black-coated generation of studs, used since 1981 (for 1982 models), the latest generation Dilavar?” No, Porsche developed a new Dilavar stud for 993 models (1995-1998), and 993 studs should be used for all repairs.
“Can anyone do this repair?” Usually you’re better off with a seasoned professional when 911 engine repairs are needed. There are an assortment of special tools needed to perform stud replacement, and it always helps for your technician to have a set of factory repair manuals on hand as well. There is no really good answer for this question, because there are probably better DIYers out there than the mechanic at the local dealer. My advice is to do your homework, ask every question that you can think of, get referrals, and then check out the shop you’re thinking of using. When you get there and you don’t see anything but a clapped-out 924 and a bunch of 3-series BMWs, rethink your choice.
Keep the Shiny Side UP!
Pete Z.
Cylinder Head Studs
FAQs:
Pete Z.
Not trying to rob the thread, but I have related question simliar to the OP.
When I looked for the car I bought (now sold and looking for Black/widebody coupe) I looked for nearly 2 years. A very large number of cars that came across my path had rebuilt engines.....many of those cars were supposedly less than 100k cars.
What would would you guys rank as the top few reasons that induces the need for a rebuild ?
I love this era 911 (own a 78SC, 83SC cab & 88 Carrera, they are responsive, you can feel them & they are just a blast to drive..
