911 Forum 1964-1989
Finally,..the WEVO RARBs are installed!
Old 08-11-2012 | 06:27 PM
dshepp806's Avatar
dshepp806
Wink Finally,..the WEVO RARBs are installed!
A good while back, I experienced a rear swaybar mount fracture on the drivers' side, resulting in my subsequent procrastination to get it repaired (ahem,..)...,..trying to work it through contacts,..blah-blah... Finally handed it over to my P-Wrench to install the WEVOs (RARB) on both sides. Replaced all rubber/clamps,..as well as new Lemfoerder drop links.
I simply cannot believe the difference that I'm experiencing as of yesterday. Knowing I had the fracture certainly contained any agressive driving over the past several months of "no-repair",..STILL,....today's run (post work) was amazing in the quick response of that rear end. Now I can push her,..and she's giving good feedback..
WOW!
CHECK YOUR SWAY BAR MOUNTS FOR ANY STRESSING!!!!!!!!!!!!!!!
Best!
Doyle
Old 08-11-2012 | 06:56 PM
Reiver's Avatar
Reiver
where exactly was the fracture...glad you are enjoying your new set up, nice when a car is dialed in.
Old 08-11-2012 | 07:21 PM
dshepp806's Avatar
dshepp806
I'll look for my pic,..but it was at the base of the previous mount structure....
Doyle
Old 08-11-2012 | 07:35 PM
dshepp806's Avatar
dshepp806
Found some:
Old 08-11-2012 | 10:23 PM
Reiver's Avatar
Reiver
Damn, no arrow needed to point that out. Was that simply a stress fracture or was there some corrosion involved?
Old 08-11-2012 | 11:21 PM
RoninLB's Avatar
RoninLB
rear sway bar mount routinely fractures on 911
temp and cheap is to weld up the crack or buy a new Porsche part
the cat's *** is the wevo mount and a good welder
Old 08-12-2012 | 12:06 AM
Reiver's Avatar
Reiver
Made me look...didn't know this was a common issue. Mine are ok.
Take a pic of your new set up when you have the chance.
Old 08-12-2012 | 01:56 AM
Amber Gramps's Avatar
Amber Gramps
https://rennlist.com/forums/911-foru...highlight=wevo
Old 08-12-2012 | 02:16 AM
Reiver's Avatar
Reiver
Amber, nice thread but you didn't show the finished product!
Old 08-15-2012 | 10:54 PM
911 Rod's Avatar
911 Rod
Once you have them installed you look at them and say "that's the way it should be!"
Install costs more than the part btw.
Old 08-16-2012 | 03:28 PM
Amber Gramps
Sorry, ended like all the other projects.
Old 08-16-2012 | 08:15 PM
dshepp806's Avatar
dshepp806
FAH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Doyle
Old 08-16-2012 | 09:31 PM
Reiver's Avatar
Reiver
Nice, what was that mattress doing in the road anyways
Old 08-16-2012 | 10:01 PM
Amber Gramps
Doyle
That was funny, wasn't it?
Old 08-20-2012 | 12:01 AM
dshepp806's Avatar
dshepp806
It certainly was,...As to my endeavor,..I provided the parts to my wrench, although he had a body shop's Master Welder handle the install (sub'd, if you will)....costs were as follows:
RARB Console/rear swaybar mount brackets (X2) 180.00 LABOR: $397
Retaining Brackets (X2) 15.00 LABOR: 0
Rear Sway Bar Bushings (X2) 43.00 LABOR: 0
shipping 15.00
LemForder drop links (L/R) + hardware 109.00 LABOR: 0
Just to share my expenses (for this particular piece) with you guys,...wish I knew how to weld.....
BEST!
Doyle
Quick Reply: Finally,..the WEVO RARBs are installed!
