Car Dies when I Remove the Oil Cap. Has This Happened to You?
I guess the question is-did you ever have the cap off before, and did it do the same? If you hadn't, how did you know if it had any oil?
If you had, and it didnt, what have you had apart?
air flow restrictor, thanks for the photos
Hi, Peter, thanks for those photos. I checked breather hose on my 82SC, air flow restrictor is missing. It is a new hose (recent restomod), so I suspect this was left out. I'll get one and see if that fixes the stall-when-oil-tube-cap-removed issue.
Andy
Andy
I'll give you a 99% chance that it'll fix the problem!
I had the opposite problem: when I removed the oil filler cap, the engine idle didn't change one bit. Three hoses were replaced and now it drops slightly just like it should...no more vacuum leak.
Still haven't found time to check the hose... my battery decided to drop a cell so it wasn't holding a charge, so getting the new battery took priority over the hose. Should be able to get all this sorted out tomorrow!
Have same problem---can't find parts....
O.k., I have same issue and my rubber piece is also cracked in multiple places. Pelican doesn't have the rubber piece in stock anymore. Any ideas where to source this? It's called a reduction pipe and # is 930-207-243-01
See diagram attached.
Thanks.
Hunter
Thanks.
Hunter
