97 993 SAI CEL
Has anybody removed the system and flashed the ECU with European ECU software... to get the CEL off...
Not worried about the Emissions stuff... I have no problem passing inspections here once the CEL light is off...
Thanks in advance...
RL Technical Advisor
FWIW,...these ECU's cannot be re-programmed with the non-OBDII ROW software.
You need to find out why you have an illuminated CEL and address that.
Where is here? Do you live in a state that has no emissions requirements.
I am not familiar with the Porsche ECU's but unless you can disable sensors and force the ECU to report a good reading, disabling the CEL alone wont make you pass.
