1987 Cabriolet - Getting new home this week
Thought I would revise now that she's mine.
Codes are: C02, 160, 220, 286, 248, 395
160 Radio "Charleston"
220 Locking differential
286 High intensity windscreen washer
395 Light metal wheels - forged
C02 Equipped with catalytic converter
Can't find anything for 248 though...
http://www.kindel.com/porsche/options/options.asp
Some oil seepage is very common on an older 911. There are many potential sources. Some of the more common include the oil return tubes, lower valve covers and engine oil cooler seals. Many of these are not terribly hard to address. With perseverance, it should be possible to address all the leaks.
The hardest part is often tracing the leak. A good first step is to thoroughly clean the motor and then see if you can spot where the oil is originating.
Thanks for the info - looking forward to this car for the summer- I also love to tinker so this should be a good car in that respect as well- as far as I can tell it only has a few minor issues to clean up
This was a total impulse surprise buy as I was actively looking for a 996 turbo- but came across this and the price, ownership, records, etc was just all right and the current owner gave me a lot of confidence in the car as it was evident that he has taken very good care of it for the last 10 years.
I think the best advice is to have the engine cleaned and then track down the leak and go from there.
Is bentley the best manual ? Where else should I be looking for diagrams and repair for DIY ?
Nice,....enjoy her,..and this NG!
Bentley is good (a must),..Factory is better! Get Wayne's (PP) book on rebuilding,.....many books out there on top of these,....
Agreed,..clean well,..THEN look for those pesky leaks........easy fixes, I bet.
Fresh fluids,..right off the batt!!!!!!!!!!!!!!!!!!!!!!!
BEST!
Doyle
BEST!
Doyle
BEST!
Doyle
BEST!
Doyle
Plug wires on that thing have been bad for a decade. Will also need distributor car and rotor before you wash the car or it is gonna sputter up a storm at start-up. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Not sure why I need to change the wires and dist cap if not having any issues - are they known to be bad and if so what's the best replacement ?
Car is being delivered tonight and I'll probably degrease the underside over the weekend - not going to touch up top other than with a rag as its already pretty clean
The ignition systems on these cars are very robust. If the car runs well, leave it alone for now. I change cap and rotor at every 15,000 mile service interval.
If you decide to do plug wires at some point, skip the Porsche ones due to the cost and buy a good OEM brand for quite a bit less. However, also skip the El'Cheapo wires too (ask me about that).
That looks like a really clean 87 Cabrio (G50), Congratulations and enjoy. I have had my 87 cab now for 14 years and it's one of the best cars ever built.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I haddah Google dat
What oil leaks?
My $.02 is with your first order be sure to include a spare DME Relay. +1 Stay away from the El Cheapo parts.
I also subscribe to the if it ain't broke then don't fix it theory. But one good thing about changing parts is that you'll have a baseline of known age. I would probably not start with ignition components right away. I'd look at brake components including hoses, pads, fluid. Expect some things like alternator, belts, starter, tires, etc to go out if you press the car into service. These are NORMAL wear items. Oil leaks are usually the oil pressure switch, thermostat o-rings, and oil return tubes. These are easy to fix. At the next oil change, adjust the valves, check the bearing (front) adjustment and re-pack if necessary. You might have the brake fluid flushed.
Awesome - thanks for the info and compliments. Took the car for the first drive today - alone - about 20 minutes just to get familiar. Making mental lists on issues to read up on. Overall I'm very happy with the car and transaction so far. I went through the records and this car has basically been sorted over the last 10 years and looks like it was well cared for from birth. Large laundry list of replacements over the years and regular oil changes.
Car also has full toolkit, air compressor and all original manuals with service stamps from Porsche through roughly 35k miles - then switched to independents. The binder also has awards from winning in 1st, 2nd and 3rd of the Early Porsche Street class of about 5 shows.
It all adds to the car.
Ordered the Bentley Manual from Pelican
Over the weekend I'm going to take some really good detailed pics of the mechanicals (is that a word) and will post.
