Adjusting door window
6th Gear
Hello,
the side window height on my 911 targa '74 needs to be adjusted.
What is the best way to do this?
Need to get my Targa top to stop leaking before the rain starts poring down again here in Norway
Andreas
[ 07-02-2001: Message edited by: Andreas Gnutzmann ]
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Andreas
Hello
remove upper door cover. there is one screw in front and one on the rear ( pluged ). Then unscrew the bezel from the mirror switch and unscrew the lock pin.
Lift off unit and you will see a set screw with lock nut for the upper stop.
Grüsse
Grüsse
