New 1975 911S owner with a question about fuses
Hello everyone, I finally pulled the trigger and bought my first Porsche. I've been lurking here a while, but I need help with changing out the Fuses.
I've run into a little trouble with the fuse blocks in the front trunk:
I do not have covers for the fuse blocks, and there are no labels in the trunk showing what amp fues goes where.
The rear fuse block is numbered 1-10, the forward block is numbered 1-8.
My question: I have no idea what size fuse goes where!
The Haynes manual is no help at all, and there are no diagragms that I have been able to find anywhere online...![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Can someone with a 1975 Targa tell me the fuse amp sizes from left to right, for the 18 fuses in the front?
Any help at all would be appreciated!!
Thanks, Dave
Thanks, Dave
This may help..
http://forums.pelicanparts.com/porsc...x-diagram.html
Google 1975 porsche fuse box...then select images and you should be able to match things up quickly.
Good luck
Good luck
Congrts on your 911s. Enjoy!!!
