Restoring rubber trim on tail
The rubber trim on my tail seems faded with streaks in it. Was just wondering if anyone has seen this and if so what did you use to clean it and bring it back to black?
Thanks, Jeremy
Thanks, Jeremy
I haddah Google dat
It depends on how bad it is. If all it needs is some light touchup, then Wurth Rubber Care or Gummi Pflege will work. I use something called LRV from The Wax Shop on everyday washings because it's cheaper than the above two.
If it's really bad, then you can try Griot's Garage. They have a type of paint that you swab on, and it actually dyes the rubber black.
