Loose Steering
Loose Steering
After replacing balljoints, installing turbo tierods, & having an alignment done & front wheel bearings tightened I'm still getting a loose feeling in the steering (its worse in the straight ahead position). I can grab both front wheels at 12 & 6 o'clock, when on the ground, and feel play when I shake them. I would have expected the ball joints & bearing adjustment o eliminate this. What else could be going on here?
thanks
Andrew (1982 SC)
thanks
Andrew (1982 SC)
