911 Forum 1964-1989
removing speedometer
Old May 11, 2020 | 04:27 PM
  #31
Rmag911's Avatar
Rmag911
Originally Posted by r911
neither
open the hood, reach way up under and pop out the oil gauge by pushing
get in the cabin and reach thru that hole to pop out the tach, and all other gauges
Hmm. My problem isnt getting the tach to stick out of the dash. I have a plastic tool I can pry the tach out with. I can get it out an inch or so. but it gets stuck between the steering shroud and upper dashboard. Doesnt seem like pushing from the outside, rather than pulling from the inside of the cabin, will address the tach getting stuck when it hits the steering shroud. But i'll give it a shot.
Old May 11, 2020 | 07:11 PM
  #32
r911's Avatar
r911
Anti-Cupholder League
oh, ok
you can either pull the very fragile plastic shroud, or try defeating the anti-fixit bolts that hold up the steering column
