Transmission plug washers?
Hi guys,
On an '87 911 with a G50 transmission, are there crush washers on the drain and fill plugs? 101 Projects doesn't mention them, but when I recently order some transmission oil from an online source, they said they include washers with the fluid. I searched for an answer, but got mixed results...some posts mention them, others don't.
TIA
Alex
TIA
Alex
The parts you need are sealing rings. The P/N for both is: 900-123-011-30
A dealer or pelican should be able to get them for you.
Please remember to remove the fill plug before the drain plug!
