911T to 2.7 engine swap
oh, and as a side note. is there any where that i can find info on this swap for the thousand other questions that will pop up? i know its been hashed over on this forum but i cannot find any of the earlier posts regarding this topic. much thanks.
You should seriously consider bypassing the 2.7 and go right on up to a 3.0. Much more reliable engine.
From a harness perspective, the 2.7 and the 3.0 are very much the same, but different from the 71T.
If coming from a salvage car, be sure to get everything you'll need to run this engine including all the attached ancillaries, the CD Box, Fuel pump, as well as the harness.
