2.7L to 3.0L swap?
2.7L to 3.0L swap?
Hi all,
I'm a 996 refugee over from the other forums. My brother in law has a 77 Targa with a blown engine. He is thinking about installing a 3.0 from a 78SC or 79. Does anyone know if this is an easy plug and play or are there many difficulties with this upgrade? He'd like to stay away from replacing the 2.7 if possible because of the inherent issues (as he found out) with this motor.
The current fuel system is the CIS. Was there much of a difference between this system and the 1978 K jet or later MFI?
Thanks.
Thanks.
RL Technical Advisor
Thats one of the easiest conversions,...
Install the 3.0 SC engine and its complete CIS and ignition system. You'll need the SC tach, too.
Be sure to add the SC's front oil cooler system to enjoy the durability of that engine, too!
Team Owner
WOW so the replacement engine he got died already ?
id be in for helping pull out the old one, problem may be sourcing a 3.0 litre . They are hard to come by due to there sheer awesomeness
Clive,
bad from the start. I guess he was sold a dud. We brought it down to Brent at Hunter Motorsport and he started it up and it blew smoke everywhere. It would require a complete overhaul.
Plan B is the upgrade to the 3.0. No more 2.7's!
One thing that may have caused the issue with the 2nd motor - no upgraded 11 blade fan so it could have been running too hot for years before he bought it. His 1st orig engine had oil leaks - perhaps head stud issues? Paper weights now!
As you point out, they can be hard to find, at least good ones anyway.
Team Owner
yeah a shame really . i remember asking him about the replacement engine at a get together last year and when he told me he got a good deal on it red flags went up . i didnt want to killl his enthusiasm however. At least you have a base for a couple of awesome man-cave coffee tables.
