Wheel "groaning" noise
SPAM addict
I noticed today on a spirited drive (with speeds up to 60 mph!) a low groaning sound coming from the left rear tire area (driver's side) when I turned the wheel to the left. Totally went away when I turned right. My repair of the day will be???![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I haddah Google dat
Groaning is usually a wheel bearing, which turns into a whirring sound like a supercharger.
Clicking is usually the CV joint.
You might check that the hub nut is tight, and try pressing sideways against the rear bumper while lookin at the whee rim. If there is movement relative to the body, then the bearing is shot.
Wheel bearing right side, if noise went away when you turned to the right it would be the left wheel bearing. could just need tightning too. I plan on replacing all 4 on mine this coming summer mostly for peace of mind, just hit 111k. More one-on-one time for me and my girl.
SPAM addict
I haddah Google dat
You need to get started on the diagnosis. The wheel rim/ movement is a sure sign. Listen to the wheel with the gearbox in neutral, or the clutch in.
If the wheel bearing does need replacement, then this is probably one the most dreaded jobs other than working on the doorstay and/or hinges. Happily, there is a puller that makes it a 5 minute job, once the brakes and stuff are out of the way. Removing the stub axle from the outer bearing race can be a major hassle unless you have a split bearing puller and a hydraulic press or a second puller.
My 2 cents.
Tim...you drove from Miami to Maine.......NO PROBLEMS.
Now, you've driven what....200 miles since being home. I'd take the spacers out and see if that resloves both your shimmy above 60 and groaning.
You said you 'personally' mounted your wheels once the new tires were on them and balanced.....I think you would have noticed 'wobble or hub play' at that time.
Tim, generally when spacers are used, the geometry of the wheel/axle are thrown out of whack. It is common for the wheel bearings to go out due to this change. Didn't you say you put 1 1/2 inch spacers on the rear? No reason to do that since I believe if Dr Porsche wanted it that way he would have designed it that way. Just my opinion. I predict you'll always have bearing problems with that much of a spacer on the car. A friend just went through that scenario. An 89 Carrera Cab with approximately 90000 miles on it. Put on narrow 993 wheels and 1" spacers on the front and 1 1/2 ones on the rear. The second set of rear bearings are already starting to get noisy.
RL Technical Advisor
Wide spacers really stress wheel bearings and shorten their life.
One simply installs the proper offset wheels for the application to prevent such issues.
Naturally, JMHO.
SPAM addict
Spot-on; these are something I would never install on a customer's car. The limit is 6mm for me.
Naturally, JMHO.
Naturally, JMHO.
My 2 cents.
Is the "groaning" chronic or intermittent? If the bearing is shot, it would be chronic. I also saw mention of a "shimmy", shimmy does not indicate a worn bearing, that is attribute to either issues w/ balance, tires or rims. Don't dismiss the fact, that it could be a hanging brake caliper!
SPAM addict
Good point. Have to look closer. BTW Damon, looking for tires for our 09 Chrysler T&C Ltd. and have done much reading on your site. Given that we live in Maine, what tire would you recommend? What is your extension? Thanks
