Scissor lift
SPAM addict
From: Acadia National Park, Northeast Harbor, Maine
SPAM addict
http://i216.photobucket.com/albums/c...1/IMG_0519.jpg
Crazy, if you have the ceiling height think about a 4 post, while your car sleeps for the winter it can be up/out of the way/safe from dings and you can detail the underside!
This is why I love my 4 post direct lift. Makes my garage bigger.
SPAM addict
My ceiling is a 12 footer.
I disagree with Ed about access. I've used both and the 4 post is much easier to use than a scissors for access for me. Scissors are great for brake work, better than a 4 post, but I've found I do more work actually under the car and can still do the tires off stuff easily.
Never store a car on a 2 post. Cars are made to stand on their feet/tires...not have the mass hanging suspended in the air.
http://i216.photobucket.com/albums/c...1/IMG_0521.jpg
Here is a pic from below...nothing in the way. I didn't move the Porsche so am standing behind and down. The black things you see center fwd are lightweight plastic drip trays to keep the bottom car clean.
Im not saying you can't do work on a 4 post, simply it is the least desirable. My point on the 4 post is that with the car on the lift, it requires secondary equipment and procedure to lift the car to get the wheels off, a necessity for routine maintenance other than oil changes, especially if one tracks their car a bit. Just about any time my car goes off the ground, it is to remove the wheels, unless I'm doing something on the motor, a rarity these days.
My comfortable roll around mechanics stool allows me to roll under and do anything I need to under the car. A scissors-type works great under a 911, anything you need to access is outside the lift itself. Also portable if needed, and non-intrusive in the garage. I only have a 3 car garage, amd don't have room for posts.
