-ve Camber. How much can you get on a '74 without camber plates?
Looking for -1.5 - -2.5 degrees camber for track and autoX. What is the max possible without going to camber plates? Can the camber even be adjusted?
Lefty
Lefty
RL Technical Advisor
Lefty:
Every car is different and ride height plays a role in the available camber range you have.
The most one usually gets is 1.0 neg, on average. You will need to modify the shock towers and add camber plates to get what you want.
If you have the budget, I can make some custom struts with offset-bored spindles that will give the camber you want without grinding on the strut towers.
