oil cooler lines & aeroquip
i ordered as set of lines w/ 30mm female ends to fit the factory ('74) hard line ends(where hooks up to loop cooler). these don't fit, anybody know what size they are? 31mm?
now how hard is it to change the end fitings? anybody in atlanta that does it?
Technical Specialist
Lifetime Member
Lifetime Member
When I've used Earl's or Aeroquip hoses in the past, I used their -16an fittings, and got a -16an to 30mm adaptor from Pegasus Racing (www.pegasusautoracing.com). They also sell -12 to 30mm adaptors. The adaptors worked just fine, mating up well with stock components.
