new carpet
Personally, I felt like the fit and finishing of the edges was very good but the overall quality of the material was below my expectations. But, does not look bad after installation and a good set of quality Lloyd mats helps.
Installation was easy, just do a few pieces at a time starting around the edges and work towards the center of the car. You will need to apply adhesive in certain areas, just clean the old gonk off with 3M adhesive cleaner first. Also use 3M brand spray adhesive, it is the best.
http://www.pelicanparts.com/techarti...tion/main2.htm
I used Original Fit as well and I didn't see any difference in the carpet quality from the others I looked at - I think they get all of it from the same place anyway. All of the pieces matched up perfect and I recieved my carpet 2 days after ordering it. (YMMV)
The one thing you need to do is remember the order in which the pieces come out and put them back in order because some of them overlap others.
There are other projects on my web sites that you may want to think about as well.
http://members.rennlist.com/5150targa
http://members.rennlist.com/myc2
Hope this helps
